Electrolux glider belt problem
Home Forums Public Support Forums Help And Support Vacuum Cleaner Help Forum Electrolux glider belt problem
  • #69465
    foxhole
    Changed brush roller and belt after vacuum pick-up became poor, but now belt just slips off motor spindle after a few seconds of use? Looks like there may be something missing on upper casing to prevent belt running off?
    #374893
    don
    Re: Electrolux glider belt problem
    Hi foxhole
    Welcome to the forums 😀
    Can you post up the all important model number please usually starting Z….
    Don
    #374894
    foxhole
    Z5740.
    #374895
    don
    Looking at the explosion there is no belt cover on the motor spindle, but there is a belt guide cover over the brush roll.
    Assuming you have fitted the correct motor and belt the only other thing I can think of is the chassis may be twisted which causing the belt to run off.
    HTH
    Don
    #374896
    foxhole
    Changed roller and belt not the motor, will try another belt.
    #374897
    don
    Sorry should have read brush roll. Was thinking about motor spindle at the time.
    Don
    #374898
    foxhole
    Has been running ok since last post but now after new belt and back to slipping off at nearly every use.
