Electrolux: Ikea Renlig DW45 : Not Draining
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Electrolux: Ikea Renlig DW45 : Not Draining
  • #93100
    JoeMac90
    P911639228/03
    Inital error 3 beeps, due to perished drain pump rubber union, this has been replaced and all water removed. Dishwasher fills ok but now has the 2 beep error.
    After filling I reset the cycles and started again to check draining.
    2 Beeps after about 5 mins.
    No sound from pump.
    Drain Pump Motor runs when not on the machine but has stuck once.
    Sump all cleaned out, no blockages or debris
    Drain pump motor resisitance: 180ohm
    Measured voltage on pump termials without pump 70V.
    Motor not running, I supect a power possible power / supply problem.
    Does anyone have any ideas what could be causing this.
    Regards
    Joe
    #453223
    Re: Electrolux: Ikea Renlig DW45 : Not Draining
    drain pumps wear as they get older. these pumps need water in them to start properly so cant be tested properly off the machine. when they fail at first it can be intermittent but if the pump is getting power and not starting on the machine with water in then its need replacing
    JoeMac90
    Hello electrofix,
    Thank you for your reply.
    The dishwasher waits for 5 minutes on startup and there are no signs of the pump trying to pump/start, then I get the 2 beep error.
    I have check continuity of the cables through all wring back to the board.and there are no problems.
    There is 40V shown across the pump cables.
    If I connect the pump to mains volts it drains.
    I think the problem could be the control board but cannot see any visible errors with components or soldering.
    Are there any sensors which may stop the pump starting?
    #453225
    no sensors put a pic of the main board up
    JoeMac90
    Here’s the picture of the board:
    Let me know if you need any more info.
    Thank-you
    #453227
    was worth a try. was wondering what sort of power supply the unit had as some cause problems but this is not one of them
    looks like it may need a new board to sort it
    part number shows as 97391163 92 28-03 / 1
    but I cant see it on any supplier.
    you could try http://www.qer.biz/servReps.htm
    and see if they repair this board
    dave
    #453228
    JoeMac90
    Thank you for your help, Dave
