Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Electrolux Inspire EDC 77570W error code 50
- This topic has 5 replies, 3 voices, and was last updated 15 years, 6 months ago by
nickslinger.
September 29, 2010 at 10:48 am #57579
nickslinger
ParticipantHi please can you hlep me I have an error code of 50 coming up on my machine. can I repair it? What parts will i NEED? I’m an ex Electronic, engineer DT teacher so not too bad repairing things. Tried local man he got £45 for saying dont understand it, could be the motor and to skip it. Just about new the machine used only about 15 times, if that.
❓September 29, 2010 at 7:56 pm #331647suedehead1
ParticipantRe: Electrolux Inspire EDC 77570W error code 50
e50 motor fault,how new is just about new.
you say you have only used it 15 times mine is on more than that every month.
check the brushes.September 30, 2010 at 1:29 pm #331648nickslinger
It is really only about 15 times, wife says 5 but I cant believe that when I cleaned out the filters. Had for about 2 years and only used in desperation. Found out from someone else that the code E51 also flashes up. Help
September 30, 2010 at 3:53 pm #331649odom
suedehead1 wrote:e50 motor fault,how new is just about new.
check the brushes.No brushes on an induction motor? 😕
E51 is motor triac. You need to obtain a new triac, which cost a few quid, and solder it onto the PCB. Worth also meggering the motor to check insulation is okay.
September 30, 2010 at 5:08 pm #331650nickslinger
Thanks for the info. 🙂
where do I buy a motor triac thing. What does it look like? I’m pulling the machine to pieces tonight.
I feel it’s do or die.!!! 👿
September 30, 2010 at 11:16 pm #331651odom
Before you order something are you sure about the E51 error code? Normally this would only be shown in engineer test mode, consumer mode only shows general E50 errors.
Motor triac is three legged component on PCB motor circuit. Unless you are competent and can understand PCBs then you really need to call an engineer, as we can’t provide wiring diagrams as per forum rules.
