ELECTROLUX INSPIRE W/M EWM14780W. PROD 914527306
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries ELECTROLUX INSPIRE W/M EWM14780W. PROD 914527306
  • #70166
    richardable
    reported fault w/m will only drain.
    checked vsrious programs and the w/m would only drain.
    customer said her son was seen pushing various buttons whilst the machine was running ( possibly on the spin cycle)
    is there a reset available?
    #377252
    Seamy
    Re: ELECTROLUX INSPIRE W/M EWM14780W. PROD 914527306
    If you go into service mode & check last fault code, post back, likely once you go in & come out of service mode it will reset.
    #377253
    A1engineer
    usually this is to do with the new type pressure sensors, as seamy says a reset usually fixes it, if not try tapping the P/S and trying again,
    last resort new switch.
    #377254
    richardable
    thanks guys
    how do i get into service mode?
    richard
    able
    #377255
    timdowning
    Just taking the pressure switch tube off is normally enough to right things.
