Electrolux oven 948904049-02
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Electrolux oven 948904049-02
  • #100547
    Micky 32
    Hi all, annoying fault with this electronic induction cooker. EKI 167662 OX
    The oven part won’t work. The touch sensor ( on the right) isn’t responding to touch. The display is on , the time 12:00 is on and a little clock symbol flashing but nothing else happens when i touch the sensors. Hob works fine on the other side.
    Any ideas? I changed the interface board but not the touch sensor board attached to the hob. Could it be that or main board?
    #481051
    cant see anything in tech
    quite complex by the look of it. from the owners manual you need A levels to operate it
    assume no fault codes come up and the child lock is not on
