Electrolux oven cooling fan not working
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Electrolux oven cooling fan not working
  • #85698
    Plaincrazy
    Hi, i`m hoping someone can help me. I have a 4 yr old Electrolux oven model no.EOB53000X, PNC 94418281702, The problem is the cooling fan does not work and there is a buzzing noise coming from the timer circuit board area. as you can guess when the oven gets to about 180 degrees it shuts down completely. i have changed the oven thermostat thinking that was the problem but still no joy. can some one please point me in the right direction?
    #429290
    Re: Electrolux oven cooling fan not working
    It’s a fair to almost sure bet you need one of these…
    http://shop.ukwhitegoods.co.uk/89966192 … an-control
    Plaincrazy
    Thanks K,
    That item is not showing on the electrolux parts page, thats not to say it hasn`t got one, but if it has where is it likely to be fitted? i`ve looked under the top cover but can`t see it.
    #429292
    There’s some images there that show you. 😉
    Plaincrazy
    There are only 2 x thermostats showing that i can see. 1 is the oven thermostat and the other is the overheat protection thermostat, neither look like the one you sent me the link to?
    #429294
    That link is to the overheat which is a common point of failure on that range. It is known as a ZN Fan Limiter.
    The other stats are rare to use.
    So far as I am aware, that limiter is fitted at the rear as shown, not under the top panel.
    Plaincrazy
    Thanks K,
    The link is for an AEG oven slightly different than my electrolux, have checked top and back and can not see it.
    perhaps this specific model has the limiter on the circuit board?
    Thanks for your help.
