Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Electrolux oven element
- This topic has 9 replies, 3 voices, and was last updated 3 years ago by
Neil_P_South.
March 18, 2023 at 11:11 am #101805
Neil_P_South
ParticipantOur lower oven is not getting up to temperature on some settings, it has 3 elements:
Upper – tested with multi meter, seems fine
Fan – tested with multi meter, seems fine
Lower – oven on “bottom heat” works fine, so I assume this element is ok. Will test it in a mo.Can an element have failed yet still show ok on the multi meter? Can something else be causing the issue?
Thanks folks
March 18, 2023 at 11:12 am #486231Neil_P_South
ParticipantModel KDFEE40X; prod number 944171721-01
March 18, 2023 at 11:42 am #486232tubafan
ParticipantIf the elements all meter ok and the connections to them are fine then the selector switch seems the next most likely candidate.
March 18, 2023 at 12:02 pm #486233Neil_P_South
Participanttubafan wrote:If the elements all meter ok and the connections to them are fine then the selector switch seems the next most likely candidate.
Thank you. I wondered if might also be the thermostat?
Also I notice the thermostat tube is connected to thin wire, which I can see some of inside the oven. I wonder if the tube just needs pushing back so the wire is not inside the oven?
March 18, 2023 at 3:13 pm #486234tubafan
ParticipantThe thermostat tube is fine – it’s a capillary tube so some of it being in the oven is no issue. You said the oven doesn’t get to temperature on some settings and that won’t be the thermostat doing that, it’ll either be an element or the selector switch.
March 18, 2023 at 4:14 pm #486235electrofix
Moderatorthe upper grill element has 2 elements on one frame
the outer one only is used as the oven element.
assume you checked both elements for continuityand its best to disconnect one wire from the element as you test to eliminate false readings
March 18, 2023 at 5:01 pm #486236Neil_P_South
Participanttubafan wrote:The thermostat tube is fine – it’s a capillary tube so some of it being in the oven is no issue. You said the oven doesn’t get to temperature on some settings and that won’t be the thermostat doing that, it’ll either be an element or the selector switch.
I’ll have a play with settings (i.e. test whether the temp is not reached on a certain “mode” such as bottom heat, grill, top and bottom heat).
Can i just check – by selector switch, do you mean the one that sets mode, or the one that sets temp?
March 18, 2023 at 9:16 pm #486237tubafan
ParticipantNeil_P_South wrote:
…Can i just check – by selector switch, do you mean the one that sets mode, or the one that sets temp?
The one that sets the mode – eg fan or bottom heat only.
March 19, 2023 at 10:51 am #486238Neil_P_South
Cheers, thanks.
March 20, 2023 at 8:44 am #486239Neil_P_South
ParticipantThis is the spare part I need …
[IMG2=JSON]{“data-align”:”none”,”data-size”:”full”,”src”:”https://i.imgur.com/SZyrmZs.png”}[/IMG2]
Looks very complicated, but according to espares video it is easy enough to install. Fingers crossed!
