Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Electrolux oven EVE616BA cutting out when heating.
- This topic has 6 replies, 2 voices, and was last updated 4 years, 8 months ago by
turboslob.
August 9, 2021 at 12:00 am #99905
turboslob
ParticipantHi, hoping for help with above electric oven.
About 5-10mins into heating up, it switches off entirely for a few minutes as if something is tripped. Then, it restarts as if you had just turned it on from the wall.
I read on this forum to replace the thermal cut-out switch, which I’ve done, but it still hasn’t fixed it. Same problem exists.
What else can I try? I recorded a video of it happening, but I don’t think it would help.
Thanks, Slob.
August 9, 2021 at 8:24 am #478434electrofix
Moderatoryou describe this as an electric oven but EVE616BA comes up as a microwave oven, Is that correct ?
August 9, 2021 at 9:45 am #478435turboslob
Participantelectrofix wrote:you describe this as an electric oven but EVE616BA comes up as a microwave oven, Is that correct ?
Hi Dave. Thanks for getting back to me.
Not as far as I’m aware.
Here’s an Australian link to info about the oven. As far as I’m aware, it’s just an electric oven.
https://www.appliancesonline.com.au/product/600mm60cm-electrolux-electric-wall-oven-eve616ba
August 9, 2021 at 4:30 pm #478436electrofix
Moderatorknow whats happened now. Lux have messed up and put a load of mocrowave info in the tech so i just assumed it was wrong
first thing to check is the cooling fan. if this is not running it will cut out
Also it shows 2 thermal cut outs, Did you change both ?
August 10, 2021 at 12:01 am #478437turboslob
Participantelectrofix wrote:know whats happened now. Lux have messed up and put a load of mocrowave info in the tech so i just assumed it was wrong
Gotcha – thanks, Dave.
Cooling fan’s still working, but I didn’t know about the second cut out. Where’d you find out about the second cut out? I don’t remember seeing a second.
Thanks, Slob.
August 10, 2021 at 8:40 am #478438electrofix
Moderatorfrom the wiring diag i found shows 2 cutouts in series so either will cut off oven
part no and temps
0541001258 190 degrees
0541001242 120 degrees
August 14, 2021 at 9:40 am #478439turboslob
ParticipantSorted! Thanks, Dave. The 120 degree is on the top of the oven, and the 190 degree is on the rear. Hadn’t noticed the one on the rear before.
Had oven-baked chips for tea and the oven didn’t cut out once!
Thanks again, Slob.
