Electrolux Oven Goes Off,also the fan stops when it reaches
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Electrolux Oven Goes Off,also the fan stops when it reaches
Viewing 8 posts - 16 through 23 (of 23 total)
  • #419188
    bcarr1
    Re: Electrolux Oven Goes Off,also the fan stops when it reac
    Can any administrator please give me any advice on my post of the
    17/10/14,as if it is the timer that could be the problem,I would like
    to order one as soon as possible.
    Many thanks
    Brian
    #419189
    Is it cycling on the main oven thermostat?
    bcarr1
    Thanks for getting back to me,I am sorry but I do
    not understand what you mean by cycling on the main
    thermostat.
    Brian
    #419191
    bcarr1
    Hi Mr KWatt,
    Could you explain please about cycling on the main oven
    thermostat.
    Brian
    #419192
    bcarr1
    Hi Mr KWatt,
    With regard to my query,I now understand what you meant,and yes the oven
    is cycling on the main oven thermostat,but goes off every time after approx. 20 minutes.Also with regard to the timer,a buzzing noise comes
    on from the timer every time the oven is switched on,Could it be the timer thatis causing the problem,or might it be the main oven thermostat.
    Hope you might be able to help.
    Brian
    #419193
    bcarr1
    With regard to my on going problem,and my last post of the 27th,
    is there anybody who can offer me advice on what the problem is,
    other than going out and having to purchase a new oven.
    Brian
    #419194
    From our remote location it is hard to reach an effective diagnosis. I therefore recommend you contact your local SERVICE FORCE approved agent for their assistance. 💡
    #419195
    bcarr1
    Thank you for getting back to me,and I understand that as you say
    from where you are it is difficult to give an exact diagnosis,however
    before I call out any engineer,I just wanted to know if there was any possibilty of the timer causing the problem,or indeed that a faulty timer
    would make no difference at all.
    Brian
