ELECTROLUX RM4400L
  • #43992
    aclarke
    THE FRIDGE WILL WORK IN GAS MODE BUT WILL NOT WORK ON THE ELECTRIC 230V MODE OR 12V, IN GAS MODE THE PILOT FLAME IGNITION IS WORKING.ANY IDEAS WHAT TO LOOK FOR
    #279337
    spimps
    Re: ELECTROLUX RM4400L
    If it works on gas then the absortion unit looks to be OK.
    I worked for Electrolux doing these through 70’s and 80’s but gave up a few years ago due to the grey areas surrounding legality of the corgi and lpg issues.
    The 230v thermostat could be open circuit and also the 230v heater would need your meter on to test.
    The 12 volt side was designed to mainly maintain a temp that had already been acheived ie,you would put it on gas/230 v prior to travelling and get it down to temp and then change over to 12 volt for travelling.12 volt is not designed for starting running from scratch.
    Don’t forget also these need a couple of hours running to get to full operation and of course be plum level !
