Electrolux slimline dishwasher – locking fill valve up.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Electrolux slimline dishwasher – locking fill valve up.
  • #30997
    whiskeyjack6058
    Went out to this the other day. It is the traditional Zanussi type with the pressure system in the sump where you remover the cover, clean out the pipes to release the blockage. I have done all that (3 times) done it with both pressure pipes removed, bottle brushed inside with the fairy liquid, (used boiling water from the kettle). After the 3rd go, realised I was going to be late for the rest of my 15 job day so I had to bail out. I have had greif with this type of job before, but not like this. Anybody any ideas? Maybe it would have worked the 4th time but the dishwasher continues to fill without clicking over to fill level 1 and locking the valve up. Arrrgh.
    Thanks….
    Rob.
    #229307
    clivejameson
    Re: Electrolux slimline dishwasher – locking fill valve up.
    Hi Rob
    Did you check/clean the horse-shoe shaped hose that loops underneath the pressure pots/syphons? (it drains the machine side of the chambers into the sump)
    If there’s no blockage there then pressure switch or harness would be my bet 😉
    #229308
    whiskeyjack6058
    No…. I havn’t done that, but I will! I know the hose you mean.
    Thanks for your help clivejameson!
    #229309
    clivejameson
    No problem 😀
    #229310
    cab
    me thinks new sump required
    cab
    #229311
    Haven’t fitted a sump in 14 years……. Horseshoe hose, every time.
