Home › Forums › General Trade Forum › electrolux tds wont work
- This topic has 9 replies, 6 voices, and was last updated 18 years, 9 months ago by
bazza500.
July 2, 2007 at 6:36 pm #28649
bazza500
ParticipantI can`t get the electrolux tds UK 2006 V2 disc to work on my new laptop.
It seems to fully install but when I try and run it it says component “DBGRID32.OCX” or one of its dependencies not corectly registered: a file is missing or invalid.
My laptop is running Windows Vista, is this the problem?
Has anyone else come across this and if so did you find a fix?
Thanks, BazzaJuly 2, 2007 at 6:58 pm #219439iadom
ModeratorRe: electrolux tds wont work
Why not try TDS 2007 ? It is now compatible with Acrobat Reader 7.
July 2, 2007 at 9:58 pm #219440bazza500
ParticipantRe: electrolux tds wont work
Tds 2006 V2 runs with acrobat 7.
Do you know if Tds 2007 will work with windows vista?
July 2, 2007 at 10:23 pm #219441iadom
Still running XP, but have just run the Vista evaluation tool, TDS 2007 does not appear to have any issues.
Unlike, Nero 6, Power DVD, TweakUi, Intellimouse and a couple of others. 😥
July 3, 2007 at 8:53 am #219442djohnston
Does it work with adobe 8
August 24, 2008 at 6:16 pm #219443mike412
bazza500 wrote:I can`t get the electrolux tds UK 2006 V2 disc to work on my new laptop.
Thanks, Bazza
I have exactly the same problem trying to get TDS to work on my new Sony laptop.
Could some kind person enlighten me please as to how to overcome this problem.Regards,
MikeAugust 25, 2008 at 7:34 am #219444bazza500
I ended up buying the 2007 version.
August 25, 2008 at 7:41 am #219445jeremy
first check in your c:windowssystem32 folder to see if the ocx is there, if it is then in a command prompt window type.. regsvr32 c:windowssystem32 dbgrid32.ocx.
if the file isnt there then you do a google for a download of it, copy it to c:windowssystem32 then run the regsvr32 command as above.
you will need administrator rights to do the above.
That should fix the error.
August 25, 2008 at 7:55 am #219446mike412
Thanks for your help guys.
I should have mentioned that mine is a 2008 version.
I have passed your info on to my son who is a software engineer, I am sure that it will help.
I will “keep you posted”.
Regards Mike
August 25, 2008 at 10:29 pm #219447squadman
I covered this a while ago, you need to run the application as adminstrator.
