We have the above freezer which is now really quite old but has run faultlessly until now.
We defrosted it as normal but when we switched it back on the compressor start relay ‘Blew up’.
It is a Danfoss relay but because it is damaged I cannot read the part number on the casing. I wonder if anyone could advise which relay I need to order please?
The freezer is a TF776W model, product code is 924523000 and the compressor is a Danfoss TL5a.
I have checked the compressor windings and get readings of 16 ohms, 16 ohms, and 33 ohms so I guess the compressor is still ok – just need to try the correct start relay if anyone can help with some information – thanks
