Electrolux W3180H, 22E error showing.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Electrolux W3180H, 22E error showing.
  • #42730
    FSE-style
    Hey pals,
    Have an Electrolux W3180H S:N 00725/0002640 washing machine that shows error 22E every 2 or 3rd time its used and wont start.
    Have been informed that
    22E The level system indicates such a wrong value at program start that the
    automatic level calibration cannot correct the fault.
    have replaced program unit card and checked pressure hose. but still comes up with the 22e every couple of times its on. When its works, it works perfect.
    anyone know of any other triggers for this error?
    thanks
    #274700
    Re: Electrolux W3180H, 22E error showing.
    FSE-style wrote: The level system indicates such a wrong value at program start
    😕 😕 Hmm, just wondering, Could it be that too much water is remaining in the machine from previous wash on those occasions when it refuses to start? (Intermittent blockage / dodgy pump?)
    Mike.
    #274701
    spanner51
    Every time I’ve seen this I take the pressure chamber off and give it a good clean. It usually cures the problem. If you get a blocked drain valve or waste pipe it usually gives error code E10
    Graham
