Re: electrolux wascator we50
It’s quite easy. Take the soap tray out. Take the machine front panel off [2 torx screws at the bottom front and one at the top at the soap drawer. [I think there are 3; it’s the lowest one].
You then have to take off the panel behind, which if I remember correctly is the drum front panel. Forgotten if it’s screwed or clipped on [it’s a long time since I’ve done one] but it comes off easily and the interlock is then accessible. I may have missed something out but once you’ve got the outer casing front panel off it’s obvious what to do next. I figured it out when I had to do it so it must be easy.
Geoff
