Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › electrolux washer/dryer 1200spin power cuts out–HELP!
- This topic has 7 replies, 2 voices, and was last updated 19 years, 1 month ago by
PompeyHero.
March 24, 2007 at 2:08 pm #26105
PompeyHero
ParticipantHi Guys
I have a electrolux aqualux washer/dryer 1200spin as soon as it powers up it blows the RCD in the main circuit board, however the 13amp fuses for machine and inline spur on the wall do not blow!
Bit of a newbie to this any help would be appreciated!!!
Regards Mark
March 24, 2007 at 3:34 pm #208794Penguin45
ParticipantRe: electrolux washer/dryer 1200spin power cuts out–HELP!
Door lock is a good bet, but would need model number to identify for you.
Penguin45.March 24, 2007 at 3:44 pm #208795PompeyHero
cheers bud
model number 91467401001 — i cleaned the filter out put it on a wash it started to fill with water then blew the rcd again, that points to the door lock yeah?
Thanks for your help bud!!
March 24, 2007 at 3:59 pm #208796Penguin45
Aha, the EW1200i built in washer dryer.
Given your latest post, it won’t be the door lock. That would be switch on, 1-2-3-bang. If it fills with water, the door must have locked to activate the programme. This is more likely to be a motor problem – it is activated after the fill sequence.
Which means it will have to come out………..
Power off when investigating.
Penguin45.March 24, 2007 at 5:50 pm #208797PompeyHero
cheers bud
by what you say, as soon as i power up 123 it blows rcd straight away..this is what happens.
regards mark
March 24, 2007 at 7:51 pm #208798Penguin45
OK – you need one of these:
http://www.ukwhitegoods.co.uk/modules.p … ducts_id=2Penguin45.
March 24, 2007 at 9:35 pm #208799PompeyHero
Penguin45 you are top boy!!
Nice one fella, dont want to take the mick!! but how does this blow the main fuse box it being a 3 door interlock?+ is it easy to install?
Appologies for the probing questions..
Regards markMarch 24, 2007 at 10:14 pm #208800Penguin45
The door lock uses a heater to energise it – this breaks down over time and will eventually short. You may have found that you’ve had to slam the door quite hard to get it to start over the last couple of months?
Door lock is on the inside of the front panel where the hook on the door goes in, so you’ll have to slip the clamp band and front of the door seal for access.
Like I said, power off….
