Electrolux washer dryer EWX14440w ‘ e13 ‘ fault code Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Electrolux washer dryer EWX14440w ‘ e13 ‘ fault code This topic has 1 reply, 2 voices, and was last updated 13 years, 11 months ago by boselecta. Viewing 2 posts - 1 through 2 (of 2 total) Author Posts May 4, 2012 at 10:33 pm #69322 boselectaParticipant EWX14440w 914602300-00 Was showing ED4 so disconnected the dryer heater, worked ok. Now two months later the customer says is stopping mid cycle. In fault code it shows ‘e13’, yet I can’t find any other fault or earth leaks with machine and inlet valves ok. any ideas? 😕 May 5, 2012 at 9:26 am #374399 CriscoldParticipant Re: Electrolux washer dryer EWX14440w ‘ e13 ‘ fault code Overall maximum water fill time exceeded (the sum of all the water fills between one drain phase and the next, to avoid exceeding the maximum volume)- Have you checked for syphoning ? Colin Author Posts Viewing 2 posts - 1 through 2 (of 2 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
