Electrolux washer dryer overfill.
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Electrolux washer dryer overfill.
  • #40381
    LONGBOAT
    Ihave 18 month old e/lux washer dryer, mod EWD14091. Got bra wire stuck inside which made its way to the hose which joins the tub to the bottom of the condenser. I have removed the wire but now the machine will not wash. It will fill to wash level then starts to wash ok but after 3 or 4 mins starts to fill again taking in far too much water until the drain pump kicks in to prevent a flood. I’m sure the pressure system has not been disturbed and if I use the rinse and spin prog it works fine. What have I done?
    #265984
    smartin
    Re: Electrolux washer dryer overfill.
    you have probably pulled off or split one of the two pressure hoses that run up the side of the drum or cabinet next to the condensor worth a check.
    #265985
    LONGBOAT
    Many apologies for delay in thanking you for the reply to my problem. It turned out to be self inflicted of course. I had removed the heater to see if I could get to the bra wire and on refitting put the heater lead that has a double connector back on the terminal but with the empty (no wire) side. So effectively had o/c heater. Interesting how a modern machine reacts though. In my day they would have just washed forever if heater gone. Thanks once again.
