Electrolux Washer EWN 14991 W (91452770601)
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Electrolux Washer EWN 14991 W (91452770601)
  • #51087
    Galway
    Hi everyone ,
    looked at this washer today ,customer said it was not turning,opened back and took out motor to check brushes and discovered it was a brushless motor .it has a digital display but does not give any error codes the there are two pumps in it and the front one seems to run all the time but the anti flood switch is not activated. it wont take in any water . 😕 it is outside its warranty since october.any ideas
    thank you
    #306893
    BobHope
    Re: Electrolux Washer EWN 14991 W (91452770601)
    earth leakage on the heater.
    Bob.
    #306894
    Galway
    thanks Bob
    i will check that.you obviously have come across this before.
    thanks Niall
    #306895
    Galway
    no earth leakage problem on the element or motor any other ideas?
    thanks
