Re: Electrolux WasherDryer playing up!!
You can replace the little fan drive belt easily enough – p/no 1240827-30/1, about £12 ( 😯 ) from memory. An email to spares@ukwhitegoods.co.uk to order.
Shreiking noises can be a bit difficult to identify. Worn drain pumps, noisy drive motor bearings, slack drum drive belt are all possibilities.
If you opt for pro help, you can use the repairs@ link below for one of us to come out. Labour rates vary widely across the country, so you should discuss this when making an appointment. Bear in mind that the machine is built-in, so the engineer will need extra time for removal and refitting as well as any repair.
Being built-in means that it is an “added value” machine, so replacement with a machine of comparable quality is likely to run to c.£500.
HTH,
