Electrolux washing machine
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Electrolux washing machine
  • #90918
    Sam72
    Wonder if anyone can help me before I spend money out that I can’t afford at the money
    I have an Electrolux model EWG 127410W just over 2 years old . It is used a lot . Last night all was going well then when I got the washing out it felt like it hadn’t had a full spin . I put it on again for spin and all was ok . Went to use it again and this time it stopped before the spin and drain program. So I used the emergency pipe to let the water out and cleaned the filter . Clothes didn’t feel like they had been washed . So I started again this time nothing . The timer works and u can see the minutes going down but nothing going on in the machine .
    Anyone have any ideas what’s going on please .
    #446458
    Re: Electrolux washing machine
    just to make life difficult there are 13 machine with the same model ( but different production codes ) so I picked a 2015 model
    although its unlikely I would check the motor brushes. most of the time these will last 5 years plus unless the machine has had very heavy usage
    Sam72
    Prod number 91452813800
    Ser number 435 00069
    Does that help Dave ? Family of 4 machine on most days and lots on Sundays – joys of teenage girls . Where do I get motor brushes from ?
    Thanks for your help Sam
    #446460
    site shop should have them but first you need to determine if its your problem
    brushes are at the rear of the motor. tilt machine backwards. tap the brush holders firmly with a screwdriver. then pull machine straight and try it. if it turns its your brushes and they need changing. if it does not turn its either 1 still your brushes and you will have to check them manually or 2 another problem
