Electrolux washing machine ewn 16781w
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Electrolux washing machine ewn 16781w
  • #73444
    paddymc
    This Machine goes to come on the door locks then goes to start but then door unlocks and it dos not come on. The red warning light only comes on when you push the start again. It blips three times with red light err (no code) . I have checked the water supply I have checked filter at the bottom right all clear out to the waste took the door lock out it is slightly burnt but I think that it is ok as the door dos lock then unlocks or could that be the problem ???. But I was think could it be the motor ??? so is there a way of testing the motor it looks hard to get out I don’t think that the motor his any brushes as I have changed those on other machines ( none profit friends and family )
    Thank for any help any one could give me as this is my mothers machine
    #387521
    captaincaveman1
    Re: Electrolux washing machine ewn 16781w
    With the main dial in the off position press and hold in the start/pause button and the next button to the left of it together keep them held in and now turn the main dial one click to the right, remove your hands and you will see all the display scrolling now turn the main dial clockwise a further nine increments and a fault code will appear in the display what is it? to exit this mode turn main dial to 0 then clockwise once and back to 0 . The motor by the way is an inverter type and so has no brushes its controlled by the electronic inverter board in the base of the machine
    #387522
    paddymc
    The err code is e24
    Thanks for the reply
    #387523
    paddymc
    Sorry it was e23 not e24
    Thanks for your help
    #387524
    captaincaveman1
    E23 relates to faulty triac on the main PCB which is used for the drain pump so my guess is either the drain pump has damaged the board possibly due to being leaked on so you need to inspect the pump or it could be due to the machine being in a damp environment and condensation has tracked across the board .
    #387525
    paddymc
    I will start at the drain punmp.But just on tooking at the pcb no burt marks i have a multimeter just need to learn how to use it. Should be ok as i have a friend how i can ring for help on using that.It is going to be a late one tonight again i will post what i come up with
    #387526
    paddymc
    Took pump of and it looks like it is burnt out so going to buy one in the ukwhitegoods store if it will fit just emailed an inquiry so see what they say and post an update
    #387527
    paddymc wrote:so going to buy one in the ukwhitegoods store
    THIS is the pump you require. 😀
    #387528
    paddymc
    New pump in did not work so looked it the pcb and could see a chip burnt so where do I get that or can the chip be replaced I have used a solidering iron before i am not to bad
    #387529
    paddymc wrote:so looked it the pcb and could see a chip burnt
    You’re up a creek without a paddle on that one Paddy. The only realistic solution is to take a close look at the damage and figure out what that fused circuit served? Was it the pump that fused it or the motor or the door lock? PCB’s don’t blow on their own accord, something caused it. And both the component AND the PCB need replacing to cure…..Bad news my friend! 🙁
    #387530
    paddymc
    Hi Martin thanks for the help looks like another one for the scrap yard
