Electrolux washing machine EWN14991W
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Electrolux washing machine EWN14991W
  • #38839
    hebegebe
    Quite a recent machine this but seemingly out of guarantee. (PNC 914527706 00)
    I wonder if there’s anyone who can throw some light on the problem with this machine?
    I was called this washing machine today. It completes the cycle, down to the last 1 minute and then sticks, with the drain pump running and door locked, refusing to end the programme. A diagnostic test (without the manual as a guide – admittedly) appeared to show that everything was normal (it wouldn’t end the drain – but no errors generated). I have just looked at the manual which gives no apparent clues.
    The last error code was E41 – but this is easily generated by starting the machine before closing the door and as the interlock appears to function normally, I have discounted this.
    The display indicates the water level during the test cycle and I have taken this as a an indication that the analogue pressure sensor is functioning normally.
    There are no obvious earth faults.
    Does anyone have any thoughts on this before I condemn the board? Any help would be much appreciated.
    Graham
    #260145
    vanish
    Re: Electrolux washing machine EWN14991W
    check the wash heater for insulation, needs to be more than 10 Meg
