Electrolux wm1000a programme wont stop turnig
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Electrolux wm1000a programme wont stop turnig
  • #46403
    alro
    Hi gents
    have a wm1000a washer select any prog and it will only bring water valve on then advances to stop any ideas pump filter was blocked cleaned did same thing advances to stop
    cheers alro
    #289218
    funkyboogy
    Re: Electrolux wm1000a programme wont stop turnig
    taco fault , spring clip holding taco in pos may have fell of
    ally
    #289219
    alro
    hi gents
    this would have given me motor action if it was taco .
    have a constant live feed to timer motor
    cheers alro any ideas
    #289220
    Sent you a file.
    As far as I can see from the diagrams, the timer motor has one side switched on the timer side, the other is a direct feed from the pcb.
