9119928014 00. Went to this fills drains detergent dispenser opens. Circulation pump will not work. No hum. removed 3 microfarad cap and replaced it with one (keyhole surgery from front) i had on the van which was taken off a faulty corroded circulation pump failure ESL6114 so unsure of if it was good as i replaced both on ESL6114. Dishwasher pump burst into life good i thought. Fitted plastic cover to cap wiring to prevent water ingress now dead again 👿 . Fitted NEW 5uF cap still dead.
Have i broken wiring by fitting cover or will it only work with 3uF cap. Or do circ pumps go intermittent on these.
It looks like the same pump as this one but PCB controlled. http://www.ukwhitegoods.co.uk/modules.p … ht=esl6114
Have genuine cap on order but would just like some info.
Re: Electrolux ZDI6896SX Dishwasher No Wash Pump action
Well fitted brand new replacement cap. Still dead. Wiggled wiring on both pressure switches above cap.Pump fired into life. Now it wont go faulty. 😕 Lots of skinny 5V wires in this one.
