Electrolux ZNB4051
  • #60865
    i have a problem with a ZNB4051 925034408 (00 20061117)
    the fridge is not cold and the display is showing – instead of the temperature.
    any ideas please
    Simon
    #343932
    anyone got any ideas on this one please
    #343933
    TheSpinDoctor
    Re: Electrolux ZNB4051
    appleelectrics wrote:the fridge is not cold and the display is showing – instead of the temperature.
    Showing what mate?
    Anyway, usually either the evaporator is choked with frost (defrost heater o/c) of the fan can cut out intermittently (fan motor assy).
    #343934
    it just shows the line –
    #343935
    martinm
    the dash in display means the fridge temp is to low.
    check if evaporator is frozen up with frost all over then its probs heater or cut/outs. If its frozen with ice at rear the probs drain blocked
    #343936
    TheSpinDoctor
    Actually, the dash shows when the temp exceeds 9oC. Given it is too warm, that would be logical to show.
