I Have one of these that will only drain. On any cycle it will just drain then flash its end light twice whilst the start light keeps flashing.
The manual says for that error the machine can’t drain but it can, I poured some water in and it drained it straight back out.
The machine is around 10 years old but has had very little use but has not had any use for the last 9 months.
I have done a search but can’t find much about it apart from someone mentioned a service mode?
Does anyone know how to get it in to service mode to see if this will clear it.
Are all the filters clean in it? Hold 1st and 3rd button switch on while holding, hold until the 1st 3 leds flash. Press the 3rd button which starts the service mode
Hi Ray
I think that one you hold down start/pause button and a option button then switch on and wait for the lights to flash then turn knob a click at a time all the way round and it will clear fault code
Thanks for the previous replies but I’m still stuck with this one.
The machine has a program dial and a start button and a delay start button. I have tried pressing and holding the buttons one at a time and then both together and then switching it on but still no joy.
I just wondered if anyone had any other ideas on how to get it into service mode?
Cheers,
Ray
