Electrulux EWX14440W — not starting fully
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Electrulux EWX14440W — not starting fully
  • #98942
    asp11
    I’ve tried it on all settings and the display works fine, it starts up on every setting but it just pumps out for a few seconds then the start light flashes – nothing else on ANY program. Brushes are ok, door lock and catch is fine……
    There is no error code……. Any ideas please
    Prod : 914602300
    Ser : 74700332
    #474419
    timdowning
    Did you insulation test the element(s)?
    #474420
    have emailed you the diagnostic info and fault codes
    asp11
    Thanks for the info…… I’ll return to test the elements & run the self test
