ElektraBregenz/Ocean/Blomberg “F07”
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries ElektraBregenz/Ocean/Blomberg “F07”
  • #28108
    ElektraBregenz WA2360 it’s shows F07.
    I’ve checked all pheriferal: doorlock; heater; pump; temperature sensor; motor; pressure switch; valves…. nothing… 🙁
    I’ve reprogram electronics with program for WA2350 it was going OK for one time but again F07… 😯
    It will be useful some info…
    Baron 8)
    P.S. Model is like Ocean/Brandt/Blomberg with main electronics in front left corner behind fascia and has timer/delay display.(no mechanic programer just setting comutator)
    #216944
    It was door lock… but mechanical part:door cable didn’t give enought space to lock in:
    F07= not locking on in asign time and
    F13= not locking off also in asign time
    Anyway if somebody has any info about Blomberg / Ocean please post to me… it will be useful in future.
    #216945
    Re: ElektraBregenz/Ocean/Blomberg “F07”
    Tech info is an on-going problem, Baron. If you still have access to the machine, you can probably “create” most of the fault codes for yourself. Take the pump out of circuit, motor; turn the water off when it’s filling, disconnect heater, NTC. They should all generate codes. I hope…… 😀
    I know this way Chris… I already done for other appliance as well as I should do for this one (time probl.) :whip: . Most of all are arriving already stuck on error and manual should help on fastest diagnose. :rtm:
    By the way, you have also some insomnia :baby: …like me? (Your post: 1:21 am)
