element keeps blowing
Home Forums Public Support Forums Help And Support Cooker And Oven Forum element keeps blowing
  • #97587
    daftoldgit
    Hello, I have a Logik LFTC60W12 cooker
    For some reason the oven element keeps blowing in a spectacular way, the whole thing’s covered in a fleece kind of effect
    I usually have to replace it about every six months, the latest one only lasted a month!
    Is this a fault with the cooker?
    Or are the elements faulty (non genuine ones from various sources)
    Any ideas appreciated, thanks!
    #468492
    from what i can see your cooker is made by Vestel
    this should be the correct gen element
    https://shop.ukwhitegoods.co.uk/32001562-fan-oven-heating-element
    i have found a lot of non gen elements are not good quality these days
    also check the fan is free running as these elements need a steady flow of air otherwise they overheat and can fail
    daftoldgit
    hi Dave, the fan spins round freely, so it might be the cheap elements at fault – I’ll try the one you linked to. Thank you!
