Re: Element won’t turn off !! Help !!
kwatt wrote:Something else is not right there Ad.
The element on and off is controlled by the thermostat and, if that were faulty, you’re right it shouldn’t click on/off normally.
It actually sounds as if it’s been wired incorrectly and that the element is getting a constant feed.
HTH
Hi Thanks for your reply.
There was only two wires which on the element I took off, and when I put it back I think they went back on the same way round but I didn’t think it mattered which way they went.
I have rang baumatic and they seem to think that its the thermostat and control unit which all comes in one, they said thats all it can be as there is nothing else like relays involed.
So fingers crossed. 😕
