Eletrolux EOB 5630X Top fan not working
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Eletrolux EOB 5630X Top fan not working
  • #17498
    poppetcedar
    Can anyone help? The oven heats up to required temp and then cuts out – the fan in the top slot is not working. The fan at the back is working though. Thanks. paul
    #174612
    gegsy
    Re: Eletrolux EOB 5630X Top fan not working
    poppetcedar wrote:The oven heats up to required temp and then cuts out – the fan in the top slot is not working.
    I think you mean the cooling fan, if thats the case, then yes it probably would cut out as it would over heat and trip the safety thermostat.
    You need to check that the fan isnt seized or its windings gone.
    Power off as always :zap:
