Hi, I wonder if anyone can help me with this.
I have an Elica cooker hood # 208339904405. The light won’t switch off with the remote control, I have to switch it off manually using the switch inside the hood. When I switch the hood on again (using the switch inside the hood) the light comes straight back on. The extractor fan works fine & can be switched on / off & adjusted with the remote with no problems. Any idea what is causing this? Is it the remote or is it the control module?
Thanks for any help.
