elica cooker hood Model 150N2
Home Forums Public Support Forums Help And Support Cooker And Oven Forum elica cooker hood Model 150N2
  • #54607
    Batts
    Had aloud bang from cooker hood-blown main fuse,Reset fuse trip now nothing works i.e lights or extcractor fan,1 bulb blown but surely fans should work without any lights.Suspect circuit board.Any ideas or where I can obtain spares Help please.
    #320318
    Washman
    Re: elica cooker hood Model 150N2
    Have you checked the fuse where the hood is plugged into.
    It should have a 3 or 5 amp fuse in plugtop or spur outlet depending on its set up.
    Washman
    #320319
    nomadPaul
    Most extractor hoods are protected by a 3 or 5 amp fuse as Washman has suggested. A bulb blowing will sometimes cause these fuses to blow . You will need to find where the plug/socket is located and check this fuse. If it has gone , please make sure it is replaced by the SAME RATED FUSE. A lot of the time , the appliance plug and socket is situated behind the extractor chimney but as i don’t know your model , i can’t say it is 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}.
    #320320
    ServEng
    replace the pcb to the hood, you may find that the motor has also gone and has blown the pcb
