Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Elica Filo IX/A/90 cooker hood
- This topic has 13 replies, 5 voices, and was last updated 1 year, 10 months ago by
Pickistitch.
May 19, 2024 at 4:08 pm #102759
Pickistitch
ParticipantI was wondering if somebody could help please.
I have an Elica Filo IX/A/90 cooker hood which has stopped working and is just making a buzzing noise. Neither the light or extractor will come on when I press the button.
Anybody have any advice on how I can diagnose the issue and find out what the issue is?
Many thanks.
May 19, 2024 at 10:19 pm #490352electrofix
Moderatorwhen does it make the buzzing sound ?
May 20, 2024 at 7:01 am #490353Pickistitch
ParticipantThanks for your reply.
so I have tried the usual first steps. Disconnect from power, reconnect etc… when I reconnect to power I can hear a buzzing noise coming from near the power in to unit…
May 20, 2024 at 8:43 am #490354electrofix
Moderatorhow loud is this buzzing ?
May 20, 2024 at 11:18 am #490355Pickistitch
ParticipantNot too loud .. more of a hum
May 20, 2024 at 3:39 pm #490356kwatt
KeymasterThe 12NC code for the hood would help, that’s explained here:
https://www.ukwhitegoods.co.uk/help/spare-parts/finding-parts/4362-elica-spare-parts
May 20, 2024 at 4:55 pm #490357Pickistitch
Participant208343104405
May 21, 2024 at 7:35 am #490358kwatt
KeymasterIn that hood like most you’ve really only get the control switch and main control module that would interact with both lights and motor but it’s important to work out which it might be and that I can’t really help with.
The two parts however are:
https://shop.ukwhitegoods.co.uk/ecb0124166-cooker-hood-power-module
https://shop.ukwhitegoods.co.uk/agc0133098-elica-control-switch-module
June 6, 2024 at 12:06 pm #490359JosephBowen
ParticipantThanks for the links, I will check them.
June 6, 2024 at 12:43 pm #490360Pickistitch
ParticipantI have buried my head since last post but realise I need to get this fixed… if I buy the parts, are they something I ca replace myself or will I need an electrician?
June 6, 2024 at 1:49 pm #490361kwatt
KeymasterThe hardest parts are diagnosis and getting to the parts, actually swapping them is pretty simple stuff.
June 6, 2024 at 2:02 pm #490362Pickistitch
ParticipantSo potentially I could try and do that myself… with your guidance?
June 6, 2024 at 2:05 pm #490363kwatt
KeymasterYes but there’s really not a lot of specific guidance that I can give you as mostly all we have and have to work from is a blowout like the attached.
August 13, 2024 at 8:10 am #490364RachelInouye
BlockedIt sounds like your Elica Filo IX/A/90 might have a power supply issue or a malfunctioning component. First, check if the cooker hood is properly connected to the power supply and ensure the circuit breaker hasn’t tripped. If the power is fine, the buzzing noise could indicate a problem with the motor or the capacitor. You might need to open the hood to inspect the motor and capacitor for any visible damage or signs of wear. If you’re not comfortable with electrical repairs, it’s best to consult a professional technician to diagnose and fix the issue safely.
