Elux EMW1100 pcbs – test sequence
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Elux EMW1100 pcbs – test sequence
  • #63932
    RocketMan
    I need the test sequence for an EMW1100 machine. Can I presume it’s similar to EMW100 models? ie rotary switch to posn 0 use start/pause and an other option button and rotate dial??
    I’ve got all the others but not EMW1100..
    Steve
    #355562
    Re: Elux EMW1100 pcbs – test sequence
    Yes indeed, start/pause plus nearest option button. Position 10 shows last recorded error. 🙂
    #355563
    RocketMan
    Martin wrote:Yes indeed, start/pause plus nearest option button. Position 10 shows last recorded error. 🙂
    Nearest option button, that’s what I needed 😀 Sounds like the rest is same as EMW1000
    Got the rest as I said: got manuals for EMW1K, 2K and 3K series as well as older stuff but nowt on this one…..
    Ta very much
    #355564
    Remind me via email at some point and I’ll send you some blurb on it.
