elux esi6100w
  • #50014
    gandh1
    another machine has entered the workshop, and still helping with repairs as we are getting a few backlogs now…
    constant chattering from dispenser solenoid when in use.
    no luck in finiding any diagnostic routines for this, however has definitely leaked into base before… been cleared, dried and still chatters… :S
    seems to work fine thought?!
    #303030
    gandh1
    Re: elux esi6100w
    edit:
    its an esi6115 😀
    got the diagnostics now but error code of l2 and end flashing??
    #303031
    Re: elux esi6100w
    Dispenser is fired by the the pcb, so either that’s faulty or there is a corruption issue feeding back through the pcb. Heater is good candidate, motor capacitor possible.
    gandh1
    Re: elux esi6100w
    was a corrupted pcb. *wince* but still cheaper than a rep d/w
    also noticed it had a different s/w code stamped on the board case – only concern now is that it seems to get awfully hot, almost uncomfortably if you touch the mastic – feels a lot hotter than what other 65 degree progs feel like on other machines… have they changed some of the wash cycle settings?
