elux ewx14440w
  • #50429
    robbo1973
    been here today when you press start the door locks it goes to start then door unlocks.i ran diagnostics and all went thru fine door locking fine etc,last error code shown was ED4 which according to the disk is wiring or pcb faulty has nayone had experience with this fault?
    cheers chris
    #304797
    Re: elux ewx14440w
    What did the megger say? Try disconnecting dryer element.
    Mike.
    #304798
    robbo1973
    Re: elux ewx14440w
    cheers for reply it was late last night and it looked a nightmare to get out so going back in a couple of days.will post findings
    #304799
    phooey69
    Re: elux ewx14440w
    had a few like that, fault is on the dryer side could be the small dryer pcb behind the main pcb on righthand side
    #304800
    robbo1973
    Re: elux ewx14440w
    thanks for replies lads been and fixed machine fault was dryer element was down to earth slightly changed and all is well again.
    cheers chris
