Anyone know fo a source of Ego energy regs (any make but must be the flat, EGO shape) that still use the threaded shaft/nut type of mounting? (rather than the now common 2 screw method) Needed for a whirlpool hob, no room to fit a diamonH stlyle, single circuit.
I checked and have not got the part you mentioned. I just noticed that there are two versions of this hob, the part number you mention is obselete but the switch on the other version is still available.
If your hob has a service number of 81/0685-00.02 then the switch is 481927328279
Thanks John, I know that and do you know what the difference is between the 2 models? Yep, mounting of regulators! Hence I turned up with the wrong one.
