Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › engineers please help..Hoover HDC884X oven thermostat switch
- This topic has 6 replies, 3 voices, and was last updated 9 years, 7 months ago by
GREENY1.
September 5, 2016 at 6:48 pm #89229
GREENY1
ParticipantHi, Just set about replacing the thermostat switch to main (bottom) oven on Hoover HDC884x….took pics of wiring on back of switch, removed and replaced new switch… 😯 😯 no pic on phone!!!
not sure which of the wires go where, can you help?one white wire and one red, one white joined together, lugs on switch No1 and No2…which goes where..thank you
ps the beer is on me if we can sort itSeptember 5, 2016 at 9:23 pm #440713admin
KeymasterRe: engineers please help..Hoover HDC884X oven thermostat sw
16 digit serial / product number required please
Bryan
September 6, 2016 at 6:16 am #440714GREENY1
ParticipantRe: engineers please help..Hoover HDC884X oven thermostat sw
Thanks Bryan, here is the 16 digit number….
Code; 33700693-0937 0364Hope you can help,
September 8, 2016 at 12:26 pm #440715GREENY1
Hi, unfortunately Bryan could not assist any further, are there any engineers out there that could help, got pics of switch/wires, got wiring scheme that Bryan emailed to me, if that helps….I can’t read it….willing to pay for info
Kind regards
vicgreen@blueyonder.co.ukSeptember 8, 2016 at 1:05 pm #440716kwatt
The only way to do it normally with info like that is to track the wiring back and trace it our as per the schematic diagram component by component, terminal by terminal, there’s no quick fix.
It is highly improbable that anyone would be able to figure it out any other way as I looked at that yesterday and it’s not the best wiring diagram for sure.
September 8, 2016 at 1:14 pm #440717admin
The wiring diagram and schematics have been supplied with comes directly from Hoover /Candy.
You need to follow the wiring to the different component parts and trace from there.
The information that you have is more than the majority of engineers have. If you can’t read or follow them then you will need to get an engineer to follow the diagrams.
Bryan
September 9, 2016 at 10:45 am #440718GREENY1
Thank you for all replies, sorted now with thanks to Paul at www. how-2-repair first class gent.:)
