EOB5630X Front panel getting hot
Home Forums Public Support Forums Help And Support Cooker And Oven Forum EOB5630X Front panel getting hot
  • #62017
    marksolesbury
    Hey
    Ive got an Electrolux EOB5630X and the front panel gets hot once the oven is switched off.
    its OK when its in use.
    Both the top cooling fan, and the main oven fan seem to work as they should
    Any ideas?
    Any help appreciated.
    #348411
    Mo3426
    Re: EOB5630X Front panel getting hot
    check the door is shutting properly and door seal is ok its also important not to turn off at mains as the fan behind the control panel needs to run for a while as the oven cools down
    #348412
    marksolesbury
    Hiya
    The cooling fan seems to run, but only for about a minute after the oven is turned off.
    does the cooling fan have a separate thermostat?
