EOD67642X bottom oven comes on when top oven selected
Home Forums Public Support Forums Help And Support Cooker And Oven Forum EOD67642X bottom oven comes on when top oven selected
  • #88352
    medionman
    hi I have an EOD67642X OVEN the bottom oven comes on when the top oven is selected
    and the bottom oven element glows red hot very quickly
    I have replaced the bottom oven element but the fault still persists
    thanks
    #437756
    Re: EOD67642X bottom oven comes on when top oven selected
    Sounds like a selector switch problem.
    Is that an Electrolux model and, if so, what’s the PNC code from the rating plate?
    medionman
    hi kwatt
    yes it’s an Electrolux
    the pnc code is 944171418 it is all electronic so no selector switch 🙁
    thanks
    #437758
    Oh poo!
    And, the top control board is also obsolete as well!
    The main power board that controls it all you can get but, it ain’t cheap, about £140 or so.
    I’d suspect the power board, one of the relays or something gone probably. But, it’s a bit of a punt.
    medionman
    yeah I have found one £136 but as you say bit expensive if its not that
    I am ex tv engineer so would not mind trying to have a look at it(may be a dry joint 🙂 )
    any ideas where I might be able to get a service/repair manual for it?
    I have just tried quickly on the net but they are all user manuals 🙁
    thanks
    #437760
    You may want to read this, then you’ll understand why you won’t get that anywhere…
    http://www.ukwhitegoods.co.uk/help/fix- … ce-manuals
    Could be a dry joint issue, dodgy relay or something so if you’re okay with electronic diagnosis and repair it may well be worth a shot, nothing to lose by trying.
    medionman
    Hi just an update
    I managed to find a service manual similar to my oven which gave me a rough idea how to dismantle mine.
    I had to slide the oven out as far as I could to reveal the top front cover(at the top of the oven). There were six screws holding this in place 2 at the side and 4 on top. Removing this cover revealed two power supplies, one small one and a bigger one in a plastic housing. there were 4 screws securing the plastic housing one of which I could not get at because it was covered by the back front cover(I could not get this cover off without removing the oven from its cupboard completely). luckily the power supply was only retained in the plastic housing by plastic clips which I managed to free. so I now have the power supply free with all wires connected. I did a diagram of where the plugs and leads went and removed the pcb. on inspection there was one small capacitor that looked as if it had been sweating a bit(the plastic sleeve had shrunk and the two pcb joints had got warm.
    Luckily at work I have access to capacitors and a solder bench so I replaced the capacitor(10 uF 35vw) and re soldered any solder joints that looked dodgy. I refitted the board loosely and …it worked 😆
    I was well chuffed .
    kwatt thanks for all your help,and on a side not while looking on line I did find a repair service for my particular power supply which was only £33.49.so anyone not able to repair their own it could be an option
