Home › Forums › General Trade Forum › epidemic failures
- This topic has 16 replies, 11 voices, and was last updated 20 years, 2 months ago by
eastlmark.
January 15, 2006 at 8:21 pm #14841
ModeratorI was thinking today about all the epidemic failures we have had over the years. It seems every era has one problem that fails in plague like numbers, some of us probably founded our businesses on some of them. from memory here is my list in, as far as my memory allows, chronological order starting when I did in the late 70’s.
Hotpoint push button extensions
Bendix/ Philco door interlocks (fault was no spin)
Zanussi & Zanussi made Hotpoint door handles
AEG door handle springs
Bendix Philco door E springs.
Indesit 2000 door interlocks.
Zanussi washcraft pumps
Zanussi washcraft door handles
Candy filter housings
Candy drum pulley faults
AEG 561 style leaking pumps
Zanussi 3 and 4 tag door interlocks
Bosch drain pumps (leaks and stalls)
Hpt WMA bearings
and up to date with
Bosch carbons
bosch/ Neff fan elements
Smeg fan elementsanything I have missed? Yes I purposly missed out Hotpoint Carbons as they have been a main stay during all this period.
January 15, 2006 at 8:33 pm #161000iadom
ModeratorRe: epidemic failures
As a former Hotpoint engineer circa 1968/80 I would add
All 1600 electronics, Timer, module & PMC. ( Power Micro Circuit)
Top loaders fitted with the first generation two pole motors, pathetic clutch from twin tub and elastic drive belt, no spin and endless pump leaks.
Original 1850 that had three door micro switches, supposed to use ‘dynamic braking’ reversing the current using the heater as a large resistor to bring the motor to a sudden screeching halt if you opened the door at full spin speed. Most of the time it just blew the electronics when you closed the door. 😥
9500 series door hinges.
January 15, 2006 at 8:35 pm #161001Bryan
ParticipantRe: epidemic failures
Nice one Mark , just off the top of my head
Hotpoint WM – Door Interlocks and Hinges and Top Restraint Springs
Beko – Fan Oven Elements
Bosch/Neff – Fan Oven Motors
Zanussi – On/Off Switches
Hotpoint – Dryer Stat Kits
Servis – ModulesSure there`ll be plenty more on the way 😆
Bryan
January 15, 2006 at 10:18 pm #161002chezza
where to start…..
indesit mechanical pumps
indesit spiders
hoover mth and gtr timers
hoover t/t dual control pump
colston t/t dog clutch
philips element/toc assy
philips hn3156 motor clutch
bendix 7147 outer tubs and shockersi even seem to remember watching in awe as our workbench was being used to repair countless hotpoint motors and modules – a skill i never did pick up completely
simplicity, yet i would pay thousands to go back to the ” good old days ” when i was learning my trade
January 15, 2006 at 10:36 pm #161003cornwell40
Philco top weight brackets (tub, motor and module gone)
Hotpoint 9525 door stuck due to pecker getting whacked. (worked for them then. Guaranteed getting home early)
Hotpoint plastic drum w/d. Front plate seal leaking.
Hotpoint 9525 door gasket retainer too big.(Take it outside to shorten it)
Hotpoint Microprofile motor choke wiring
Ah the good old days 🙄Tony C
January 16, 2006 at 8:13 am #161004Martin
Parnall wringer rollers
Hoovermatic OCV’s:rotl:
January 16, 2006 at 9:42 am #161005TOWAN
zanussi d/w rinse aid dispenser leaking onto wiring harness and catching light!
during the late 80,s and early 90,s all the models had to be visited,checked and modified if faulty.
was a good overtime earner!January 16, 2006 at 10:08 am #161006Goatboy
Hpt/Creda T/D belts,
Hpt’s with cracked bases,
Zanussi bearings,
Whirlpool winged nuts,
Italian Electrics (abit of a generalisation)January 16, 2006 at 5:56 pm #161007leavemetogetonwithit
Hoover and Hotpoint pressure vessel blockages and element failures. Rarely get those now 😥 since moving to this soft water area. But get plenty of spider rot.
Mike.January 16, 2006 at 7:32 pm #161008farmboy
TOWAN wrote:zanussi d/w rinse aid dispenser leaking onto wiring harness and catching light!
was a good overtime earner!And not forgetting the Z30 / DW400 wiring loom recalls and the 1200 spin washing machine motor failiures.
January 17, 2006 at 12:33 am #161009Penguin45
Gentlemen……..
The star of this particular little show, and playing in an appliance near you……..
The magnetic drain pump motor.
A boon to repairers since 1992 and still no improvement. It can’t really get much better, can it?
January 17, 2006 at 11:06 am #161010leavemetogetonwithit
Chris. Would you say they are that much worse than the old ones? And don’t forget they use 30 watts as opposed to 90 although they may take longer to pump out a drum. ❓
Mike.January 17, 2006 at 11:19 am #161011iadom
I would say much worse, the failure rate is three or four times that of a ‘decent quality’ shaded pole motor. 😥
January 17, 2006 at 1:00 pm #161012leavemetogetonwithit
iadom wrote:a ‘decent quality’ shaded pole motor. 😥
I’ve had to change quite a few AEG old type pumps which leaked. Was this just because AEG machines last longer, enough time for the pumps to fail or were their pumps not “decent quality”?
Mike.January 17, 2006 at 5:29 pm #161013iadom
They may have leaked after several years, modern pumps are noisy within 12 to 18 months, and fail at an alarming rate. This afternoon I went to a Hotpoint 18730 around 25 years old, unfortunately the backplate had gone but the original pump which was manufactured by Hotpoint themselves is still perfect.
