Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › er8034I electrolux fridge/freezer
- This topic has 7 replies, 3 voices, and was last updated 17 years, 11 months ago by
Galway.
April 23, 2008 at 5:10 pm #36236
Galway
Participanthi all ,called to this customer today ,the freezer is ok but the fridge is not cooling and compressor is running constantly.The evaporator fan is running but the evaporator and defrost heater are covered with ice .
i dont do much with fridge/freezers so am wondering is this a defrost problem any ideas appretiated. 😕
thanksApril 23, 2008 at 6:56 pm #250139BobHope
ParticipantRe: er8034I electrolux fridge/freezer
Hi Galway
the air return vent for the fridge will be blocked with ice, its located behind the freezer evaporator,
check the defrost heater is working by turning the defrost timer manualy to the defrost position before you start to defrost the evaporator, if it is ok and the freezer door has not been accidently left open change the defrodt timer as a precation.good luck.
Bob.April 23, 2008 at 8:10 pm #250140Galway
thanks Bob
can you tell me where the defrost timer is located on this as it is an integrated model and did not take it out and will a manual defrost clear the blockage
thanksApril 23, 2008 at 8:17 pm #250141BobHope
hi Galway
looking at the TDS disk its located at the rear of the appliance next to the compressor.
do a manual defrost and make sure you get that vent cleared.
Bob.
April 23, 2008 at 10:00 pm #250142Galway
ok thanks for that 🙂
May 14, 2011 at 9:37 am #250143dave-m
Galway wrote:hi all ,called to this customer today ,the freezer is ok but the fridge is not cooling and compressor is running constantly.The evaporator fan is running but the evaporator and defrost heater are covered with ice .
thanksLong time ago i know, but did you ever sort it? I’m going to the exact same problem on Monday.
CheersD
May 15, 2011 at 9:49 am #250144Galway
did a manual defrost and havent heard anything since
May 15, 2011 at 9:58 am #250145dave-m
I told him to do that before I call out and it made no difference so looks like I have another problem.
I’ll find out tomorrow, cheers.D
