Re: error 4 on integrated diplomat 8322
Have a look in the sump beneath the filter…at about the three o’clock position is a black grid, it will be crudded up inside.
Clean with hot water and toothbrush but don’t poke anything sharp through it, there’s a rubber diaphragm behind which can be punctured.
If the muck is particularly stubborn then it will need removing from underneath (bayonet fit onto the sump)and carefully disassembling.
Power disconnected at all times :zap:
