Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Error 63 – Bosch Logixx 8 Washing Machine
- This topic has 13 replies, 7 voices, and was last updated 18 years, 8 months ago by
nr84.
July 17, 2007 at 7:33 pm #29083
nr84
ParticipantCany anyone help identify this message? F:63 displayed on Bosch Logixx 8. It won’t clear even when you’ve switched off at the mains then back on again. We’ve emptied it, taken the water out, sworn at it and all sorts…
HEEEELP!!
July 17, 2007 at 7:34 pm #221441gegsy
ParticipantRe: Error 63 – Bosch Logixx 8 Washing Machine
Need the model number off the stainless steel of door please.Greg
July 17, 2007 at 7:37 pm #221442nr84
Ah, think it’s WAS32466GB – does that seem about right?
July 17, 2007 at 8:38 pm #221443macmini
Are these not under two year old?
If so, they’re still covered under your warranty, contact the retailer you bought from.
July 17, 2007 at 8:39 pm #221444nr84
Thanks for this – I think!
The last bit is /03 – wouldn’t care but it’s just out the wrapper – just installed yesterday – started it off and it filled with water then “hung” (sorry I’m an IT person!) – tried to reboot but to no avail…
Hopefully it’s covered by warranty
Cheers
NickiJuly 17, 2007 at 9:08 pm #221445gegsy
I would do as macmini says and return to retailer if its brand new as this has a fault, just one of those things 😕Greg
July 17, 2007 at 9:18 pm #221446whitevanman
nr84 wrote:😯
Cheers
Nickijust a thought, if you didn’t have a dishwasher before and you have fitted the drain hose under the sink , check that the end has been cut off.
Wvm
July 17, 2007 at 9:51 pm #221447superfix
I agree try removing drain hose from waste and placing it in a bucket. Then try to drain the m/c.
Otherwise you will more than likely face a call out charge if it’s not the m/c that is faulty.
July 17, 2007 at 10:03 pm #221448gegsy
Wouldn’t you get F13 for drain problem instead of F63 which is an error in the power module :con: 😀
July 17, 2007 at 11:15 pm #221449Penguin45
Isn’t it a washing machine, anyway?
July 18, 2007 at 7:35 am #221450gegsy
Penguin45 wrote:Isn’t it a washing machine, anyway?
Yea :oops:, but fault code still stands 😀
July 18, 2007 at 7:41 am #221451Martin
gegsy wrote:Wouldn’t you get F13 for drain problem instead of F63 which is an error in the power module
Hang on! I’ll got to Trade Tech and look up ‘Bosch error codes’, I expect there’s a list there somewhere….BRB! 😉
July 18, 2007 at 7:44 am #221452nr84
Hi, yes it’s a washing machine…but I checked the drainage pipe anyway and it’s okay. Hopefully we’ll get someone out to fix it – or replace it – in the next day or two…the washing is piling up!
July 18, 2007 at 8:10 am #221453gegsy
Martin wrote:
gegsy wrote:
Wouldn’t you get F13 for drain problem instead of F63 which is an error in the power moduleHang on! I’ll got to Trade Tech and look up ‘Bosch error codes’, I expect there’s a list there somewhere….BRB! 😉
:clown:
