Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Error Code 06 for Brandt Washing machine. Model WFH 167U
- This topic has 4 replies, 4 voices, and was last updated 20 years, 6 months ago by
odnek.
October 2, 2005 at 8:42 am #12310
odnek
ParticipantCould anyone tell me what the above error code (06) means.
I changed the brushes in June and worked fine. now the machine will begin to wash and then flip onto theis error code and stops.
Can anybody shed any light on this. I’m begining to think I’ve bought a bit of a pup as it is only 2 years old and this is the third fault I have had with it. The other critisism is that it is difficult to find out what the error codes mean so if anyone can shed light on where I can find them out it would be great.
CheersOctober 2, 2005 at 9:54 am #149027Washman
ParticipantRe: Error Code 06 for Brandt Washing machine. Model WFH 167U
Fault code 06 is most likely a motor tacho fault , which means a problem with the motor . Possibly time for an Engineer to look at machine.
If your going to look SWITH OFF AND PULL THE PLUG OUT FIRST
And check the brushes again .Mike
October 3, 2005 at 9:28 pm #149028odnek
ParticipantAny idea how much a new motor for this machine will be and where can I get one?
October 3, 2005 at 9:54 pm #149029Dave_Conway
Part number 55X7765 at £125.00 inc VAT and delivery odnek 🙁
If you want one, let me know, an email to spares@ukwhitegoods.co.uk please and I can arrange for you.
February 9, 2008 at 10:16 pm #149030simmo66
ok, I know this thread is 3 years old, but it might help someone to know that my Brandt just packed up, and I had A LOT of trouble finding info on it like error codes etc.
Gist of it is I had err06 and no spin. Replaced brushes and still no joy (old ones were only half worn anyway). Checked continuity in loom from PCB to motor, and found a boken wire at the motor end multi-pin plug. Remade the connection, and BINGO! Machine now works fine.
I suspect the original poster had a similar problem. He probably disturbed the wires in the process of replacing the brushes, which remade the connection temporarily.
ps it’s a Selni motor, if anyone needs to know 😉 -
