error code
  • #21121
    happycack
    Hi,, Can you tell mme what the error code on an Indesit W103 refers to when the dial rotates and the on/off button flashes 8 times,, stops thhen repeats itself. I have tried the normal re-set routine.
    Thank you.
    #189587
    Re: error code
    It is a heating fault, either the heater is faulty, the thermistor faulty, the main circuit board faulty or all three? 🙁
    Power off before investigating of course…!! :zap:
    #189588
    happycack
    Thanks Martin. I’ll get me Mega out!
    Where can I get a complete list for these codes?
    Regards
    Happycack.
    #189589
    happycack wrote:Where can I get a complete list for these codes?
    They are locked in a chest at the end of the rainbow! 😉
    #189590
    happycack
    Does the rainbow have a call-out charge?
    #189591
    happycack wrote:Does the rainbow have a call-out charge?
    No, no, but the conditions have to be right for the phenomenon to appear. :rolls:
    But for now at least we’ve managed to shed a ray of bright light onto the problem with your machine hopefully. 😉
    #189592
    happycack
    Thhanks Martin.
    #189593
    mr_paul_mchugh
    Re: error code
    Post removed, along with two others Admin edit.
    There is no need to post the same thing three or four times, once is quite enough thank you.
