Error Code E04 on a Hoover WDYN 9646G-80
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Error Code E04 on a Hoover WDYN 9646G-80
  • #81945
    irnbru
    Switch machine on and after a few minutes the programme display reverts to showing this error code. No activation of filling prior to the code fault display.
    Have already changed pressure switch checked for blockage in tube etc.. but no change – any ideas?
    #418238
    Jackal
    Re: Error Code E04 on a Hoover WDYN 9646G-80
    If pressure switch and tube are both ok, it’s either of the following:-
    1. Faulty inlet valve;
    2. Damaged or loose wiring;
    3. Faulty Coreboard
    3 is the most likely.
    Jackal
    #418239
    irnbru
    Jackal wrote:If pressure switch and tube are both ok, it’s either of the following:-
    3. Faulty Coreboard
    Jackal
    Thanks for the guidance –
    No power through to 3 way inlet valve on cw port therefore assume that it’s the coreboard – is this the program module or pcb c/w display?
    #418240
    Jackal
    Coreboard is the Main PCB NOT the display PCB
