Error code E08 Hoover HWB814DN1
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Error code E08 Hoover HWB814DN1
  • #91646
    Mike8
    Hi, I have an error code E08 on a hoover HWB814DN1 washing machine. Google tells me it’s the brushes or more like the tacho.
    The brushes are fine, the resistance across the tacho is steady at just over 43 ohms and varies when the tacho is rotated. It has been running noisy, so I know the bearings are a bit ropey, but the drum and motor are easy to turn by hand. Any ideas please?
    #448862
    kaibart
    Re: Error code E08 Hoover HWB814DN1
    You know it’s a motor fault so the motor will need replacing as long as you have continuity through the wiring to the motor. 😉
    #448863
    Mike8
    Thanks kaibart
